Shorting out the mobo.
Anything bad with socket CPU.
Anything with Video Card.S
Stuff like that.
Someone told Luke and Linus at CES 2017 to "Unban the legend known as Jerakl" and that's about all I've got going for me. (It didn't work)
Personal threats? 24 pin Power connector and
threats by fear, used the wrong word...
Stuff like that.
anything like plugging in the wrong pin and shorting out the mobo with your nervous sweat? Lol
Nuggets In Pajamas
When you put the CPU in the socket then press down on the mechanism, I'm always scared that the CPU pins will get destroyed or something.
I know it's meant to work like that and I've never had any issues, but you have to press so hard! The 24 pin connector is scary too because you feel like you're going to bend and snap your motherboard in half.
"Common sense is not so common." -Voltaire
BENDING ANYTHING.
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
I dropped my CPU on the floor. The gold side down... Works find though
So the only hazard was me .
build everything
press power button
nothing happens
cry in a corner
notice cable not plugged in correctly
Glimmer of hope
try button again
nothing happen
cry in corner
YOUR TEARING ME APART !!!
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
BENDING ANYTHING.
not that much if u have a metal backplating backing ur mobo like the maximus vi formula
build everything
press power button
nothing happens
cry in a corner
Glimmer of hope
try button again
nothing happen
cry in corner
did that happen to you? If so, condolences to your family
Nuggets In Pajamas
Hehe.
You know what I mean.
I don't sweat a ton when building PCs.
The room always seems warmer however.
I think I might have to add RMAing stuff to the list.
I hate when I get half way through a difficult build and realize there is more than one part D.O.A. Rare, but it's happened to me before!
Also, when water cooling... Leaks! Shorts! Cries! Retries!
« Current PC ~ Phantom Beast »
threat/fear: case of the dumb ass is what can be controlled and that is a tall order to keep.
wat. Can u be more specific?
leaks, especially leaks
Nuggets In Pajamas
Losing that one screw.
[spoiler=pc specs:]cpu: i5-4670k | mobo: z87-pro | cpu cooler: h100i | ram: 8gb vengeance pro | gpu: gtx770 ftw 4gb | case: nzxt switch 810 matte black | storage: 240gb ssd; 1tb hdd | psu: 750w corsair rm |
keyboards: max nighthawk x8 mx brown + blue led; corsair k60 mx red; ducky shine 3 tkl mx blue + orange led | mouse: deathadder black edition | audio: FiiO E10; sennheiser hd558; grado sr80i; sony mdr-nc200d; blue snowball |
forgetting to finish tightening down mobo/heat sinks,
removing protective layer from CPU block,
to use TIM,
connect all PSU connectors to motherboard,
connect PSU harness to GPU, the list is long and distinguished.
rma? Please do define
When you a part is defective.
So then you have to return it through warranty for a replacement.
to use TIM,
is plugging in the wrong pin part of the list?
oh i get it, and they dont accept an exchange because it was "our fault"
Nuggets In Pajamas
Cheap cases that cut you and crappy PCI brackets where you have to cut it out
CPU AMD Ryzen 5 3600x | GPU GIGABYTE GTX 1070ti WINDFORCE | MOBO ASUS Prime X570-P | MEMORY XPG Spectrix 2x8GB 3200MHz  | PSU OCZ Zx 850W | CASE NZXT H440
No they will accept if it is within warranty.
It's called an RMA because RMA is an acronym for.
Return Mail Authorization? I think.
