Apart from the main pc components, what do u need to build a pc?
Solved by LogicalDrm,
-> Moved to New Builds and Planning
Apart from couple of people too picky or not reading the thread...
So you don't need thermal paste. That comes with the stock cooler, or most of the aftermarket coolers.
You need stable surface, with non-conducting material, good light and phillips head screwdriver. You need to ground yourself, but that can be done with anything metallic connected to wall socket. Like a desk lamp. Plus time and patience.
