Looking for Best fans, how are these for a cross between silence and power?
ya the info on the box is proven to not be right. and we dont have a way of testing it. people have tried for years. gn is working on something to test it in there new studio and will cost $30,000usd for it. un till then all numbers and test are no 100% accrete. its proven higher dbs fans may be louder but the pitch may seem quieter and it all depends on what your ears can hear so....
most people run the fan slow at idle and max when gaming if they use headphones. if they dont then you find a fan curve that you can tolerate. if you need more cooling look at other options before going max fan rpm.
we dont even no the build or what the temps are so all we no is "whats the best fan" and each will have there own opinions on witch one that is.
i like the gentle typhoons and i can pick em up for about $20 can and in there un accrete test it came out on top.
and you can add argb grill or 2 if you fell ballszy but your looking at like $40-$60 per fan...
