6 Fans @ ~ 700 RPM for intake ?
That all depends.
1. Is anything thermal throttling? If nothing is thermal throttling then so long as 2. You are happy with how loud the computer is at both idle and under load then, Yes that is fine. If the computer is thermal throttling then you will want to look at increasing the RPM of the fans. If possible you could scale the fan RPM with temperature.To maintain both quiet operation at idle and effective cooling while under load.
Featured Topics
Mnemonically_impared ·
Posted in General Discussion0 -
DxD ·
Posted in Troubleshooting1 -
4
3
4
TheEgg ·
Posted in Phones and Tablets9 -
AleksiDj73 ·
Posted in Peripherals8 -
Micro2000 ·
Posted in New Builds and Planning6 -
djksm ·
Posted in Member Reviews2 -
DarthAegon ·
Posted in New Builds and Planning10
