Monitor Suggestion
Solved by SolarNova,
If HDR is that important to you then really the only monitors, that have been tested and reviewed*, worth looking at are the following.
https://www.rtings.com/monitor/tools/table/59551
Ranging from roughly £600 to £1500.
Most monitors, even those that advertise HDR support, simply cant produce a reasonable HDR experience when compared to good TV's..
*You may find a few monitors not listed here that have been reviewed by other reviewers, rtings is the easiest to list.
