Getting high temps on a Ryzen 5 3600 with stock cooler
Solved by Guest,
3 hours ago, Biohazard777 said:Just so there is no confusion for you or the OP, the picture I posted was to show the difference between the 3 stock coolers side by side.
Prism has a copper cold plate and copper heat pipes, has a large area to dissipate heat. Overall pretty good cooler, on par with some single fan tower coolers.
Spire... even though it has a larger chunk of aluminum compared to Stealth, that is about it... no copper to be seen. Pretty much any 20$+ tower cooler will beat it.
Stealth is absolute garbage tear, the only thing worse than it is the smallest Intel stock cooler.
Just making sure. +1 verification
