Im a student about to move into student accom and i was wanting to get better fans as my current ones are very noisy when spun up and can still be noisy when running slower.
I am running a corsair 750D but might move to the smaller 5000X/D
Current fans
2 intake HD140
an exhaust fan standard corsair that came with the case
3 fans on the 360mm aio h150i pro - these arent as loud
https://linustechtips.com/topic/1353762-best-fans/
My recommendation would be Noctua's NF A14s or Thermaltake Toughfan 14s for intake and their 120mm variants for the rad. Unless you're including RGB. In that case, I'd just buy a couple rgb fan frames and call it a day.
Salisbury steak isn't steak.
https://linustechtips.com/topic/1353762-best-fans/#findComment-14851935
Noctua. If you don't care about RGB, Noctua is your one stop shop for silence.
You can save some money and just do Thermaltake ToughFans. On noise levels they are comparable but longevity hasn't been tested as they are too new.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1353762-best-fans/#findComment-14851936
Indeed, for 140mm's
Otherwise Noctua NF-A12x25's which are higher quality than thermaltakes toughfan, just they only come in 120mm and brown.
I don't think you can get better than these, they have both high airflow and high static pressure, most are one or the other.
System Specs: AMD 5950x PBO-AutoNoctua DH-15 Black | Gigabyte x570 MasterEVGA 3080FTW3 Ultra | (2x16gb) G.Skill Royal 3600mhz CL18 | Corsair 5000D Airflow (Black) Samsung 980 Pro 2TB & Firecuda 520 1TB & Crucial MX500 2tb850W Corsair RMX | 2 Noctua A14 CPU, 6 Noctua A12x25 Intake, 3x Noctua F12 Top Exhaust, 1x Noctua A12x25 Back Exhaust
Monitors: (Main) LG Ultragear 34" 2k Ultrawide 144hz IPS '34GP83A-B' (Side) Acer Predator 27" 2k 144hz TN 'Abmiprz'
Peripherals: Corsair K100 OPX | Logitech G502 Lightspeed | Corsair Virtuoso SE | Audioengine A2+
https://linustechtips.com/topic/1353762-best-fans/#findComment-14852264
1 hour ago, Unknown_origin said:
what about with rgb
hard to say what the best argb fan is but they get up words of $50-$75 a fan...
https://linustechtips.com/topic/1353762-best-fans/#findComment-14854457
2 hours ago, Unknown_origin said:
what about with rgb
Arctic P12 ARGB is the best ARGB fan. its also better than many non ARGB/RGB fans
https://linustechtips.com/topic/1353762-best-fans/#findComment-14854555
best at what? rad fan case fan nose? you bought and tested other argb agents it?
https://linustechtips.com/topic/1353762-best-fans/#findComment-14854560
Rad-T to noise just like 25x12 and P12.
Tested: QL, ML, HD, Phanteks SK ARGB, Vardar, CM120R, CMMirage, Arctic P12 ARG, P120 ARGB, Lian unifan
thats the RGB part of it
https://linustechtips.com/topic/1353762-best-fans/#findComment-14854576
thats not all the argb fans...but w/e might be the best out of thows
https://linustechtips.com/topic/1353762-best-fans/#findComment-14854583
9 minutes ago, NorKris said:
True, but you name another good one and i will prob test that too 😛 .. i dont rly know any other good rgb fan
https://www.amazon.ca/Cooling-Install-2000RPM-Radiator-Desktop/dp/B08LQ113MB/ref=sr_1_52?dchild=1&keywords=14+cm&qid=1625593814&s=pc&sr=1-52
i found the 12cm version
https://www.amazon.ca/Silent-2400RPM-Computer-Cooling-Desktop/dp/B08QSFXQ5H/ref=sr_1_845?dchild=1&keywords=12+cm&qid=1625594244&s=pc&sr=1-845
Edited by thrasher_565
https://linustechtips.com/topic/1353762-best-fans/#findComment-14854593
https://linustechtips.com/topic/1353762-best-fans/#findComment-14854649
8 minutes ago, NorKris said:
hmm fun. never seen / heard of..
kinda strange that they dont show the front 🤔
ya its like Facebook angles.... but i got the non rgb fan and man i was blown away thow i didn't pay$20 for em i payed $10.50. and $20 ied go with dark side Gentle Typhoon
i got the 14c argb one coming as well and only paid $9 each so... but that not the normal price.
looks like there a 3000 rpm would be nice to have and see thows...
https://linustechtips.com/topic/1353762-best-fans/#findComment-14854672
heres a pic of the argb dose not look grate...
https://www.gearbest.com/other-pc-parts/pp_009164637399.html?wid=1433363
https://linustechtips.com/topic/1353762-best-fans/#findComment-14854730
Looks like a 4 or 6 LED fan. hmm
Btw i took a multimeter to a 8 LED fan:
105,6 mA for Red or blue or Green
206 mA for yellow
260 mA for white
Rated for 190-200mA from manufacturer
https://linustechtips.com/topic/1353762-best-fans/#findComment-14854780
206 mA for yellow
260 mA for white
ya white use all 3 colors so test should be with white on max brightness. but different chips will use different amount of power.
https://linustechtips.com/topic/1353762-best-fans/#findComment-14854802
2 hours ago, thrasher_565 said:
Honestly? If those stats are right, the fan at 600rpm producing 55cfm @ only 18dba is really awesome. It seems too slow to be moving that volume of air though; Note the NF-A12x25 only claims a max of 103 M3h (60CFM) at 2K RPM and 22dBA
https://linustechtips.com/topic/1353762-best-fans/#findComment-14855069
manufacturers numbers have been proven to be flawed and any fan test we do is also faled. gn is working on a way to test fans but like a few years down the road with an $30.000usd
testing static pressure has also bee flawed.
so the stats mean nothing really in the end.
all i no is the fan i have is quiet and pushed a lot of air.
https://linustechtips.com/topic/1353762-best-fans/#findComment-14855133
Current fans
2 intake HD140
*i repeat dont forget to check the prices of FANS*
for longevity NOCTUA
for temporary Arctic's P14 considering you are going to change them when you have good budget
https://linustechtips.com/topic/1353762-best-fans/#findComment-14856504
