CPU at 90C with 360mm Fractal S36 (R7 5800x)
Solved by static773,
21 minutes ago, static773 said:Ill go check if its still under warranty. It should be as its a 5 yr old warranty
Im back, its still under warranty. I will try an RMA but if that doesnt work im going down the custom water cooling route. Thank you!
Featured Topics
Fireord36 ·
1
azyrroth ·
Posted in Home Theater Equipment0 -
Andrew john ·
Posted in New Builds and Planning24 -
2
