I have a Vega 64 and rx570 with 0.5-1 slot space in between (gpus on 1st and 2nd pcie slots). Obviously, they run hot, especially if gaming or rendering. I don't want to have my case open, Lian Li dynamic (1st gen), even though, they're still hot. Having an GB Aorus Master motherboad, what would be a good option for case for the gpu to be on 1st and 3rd? Any ideas?
Looking at these pics, I don't know how the temps are like, look concerning.
https://pcpartpicker.com/b/kkP323
https://pcpartpicker.com/b/wXdmP6
https://forums.macrumors.com/threads/dual-radeon-vii-5-1-build.2220238/?post=28154463#post-28154463
https://linustechtips.com/topic/1326295-case-recommendation-for-dual-gpu/
You'll likely want something with a side mount fan option like the Cougar MX 331 Mesh-X.
I have two 1070ti's stacked on top of each other in a Level 10 GT (which also has a side mounted fan) and temps are solid despite running 24/7
https://www.google.com/url?sa=i&url=https%3A%2F%2Fpcpartpicker.com%2Fb%2FkkP323&psig=AOvVaw1V9AtapVa-MM8dYS5-Sf3f&ust=1618414737185000&source=images&cd=vfe&ved=0CAIQjRxqFwoTCKC4wO_G--8CFQAAAAAdAAAAABAD
https://www.google.com/url?sa=i&url=https%3A%2F%2Fpcpartpicker.com%2Fb%2FwXdmP6&psig=AOvVaw1V9AtapVa-MM8dYS5-Sf3f&ust=1618414737185000&source=images&cd=vfe&ved=0CAIQjRxqFwoTCKC4wO_G--8CFQAAAAAdAAAAABAJ
https://www.google.com/url?sa=i&url=https%3A%2F%2Fforums.macrumors.com%2Fthreads%2Fdual-radeon-vii-5-1-build.2220238%2F&psig=AOvVaw2gDhLqBBzEJqZXFoZBlW2r&ust=1618414862525000&source=images&cd=vfe&ved=0CAIQjRxqFwoTCKi57KrH--8CFQAAAAAdAAAAABAJ
Links have redirects which are arguably even worse than don’t work.  Hard to know where they are going to go.
lot of heat means you need a lot of available air flow. A case with good from AND side airflow seems like a good idea so @TVwazhere’s suggestion makes a lot of sense.
this is case i use it seems to keep ever thing cool but i has no side window and is HUGE
 https://www.rosewill.com/product/rosewill-thor-v2-gaming-atx-full-tower-computer-case-supports-up-to-e-atx-xl-atx-4-preinstalled-fans/
KanyeWestLover911
Reminder
I'm just speaking from experience so what I say may not work 100%
I Use Arch BTW
my PCs
these are my Pcs
https://pcpartpicker.com/user/mtj08/saved/
Thanks! That particular is not available in Canada. Do you have any other recommendations?
The side fan, would be intake or exhaust?
Fixed the links. 🙂
Intake; feeds the cards directly with fresh air.
The MX330 is the predecessor to the 331 and seems to have availability in a few Canadian stores 🙂
https://ca.pcpartpicker.com/product/XZnG3C/cougar-mx330-x-atx-mid-tower-case-mx330-x
https://ca.pcpartpicker.com/product/V8Dkcf/cougar-mx331-mesh-x-atx-mid-tower-case-mx331-mesh-x
I really wanted to get this case to replace the one I have right now. But this thing only uses 120 mm for front intake while I currently have 2 140 mm Noctua P14S Redux. That means I'll have to buy new ones. Man oh man.
Main Rig :
Ryzen 7 2700X | Powercolor Red Devil RX 580 8 GB | Gigabyte AB350M Gaming 3 | 16 GB TeamGroup Elite 2400MHz | Samsung 750 EVO 240 GB | HGST 7200 RPM 1 TB | Seasonic M12II EVO | CoolerMaster Q300L | Dell U2518D | Dell P2217H |
Laptop :
Thinkpad X230 | i5 3320M | 8 GB DDR3 | V-Gen 128 GB SSD |
this is an ok website to look at case
https://www.newegg.ca/p/pl?N=100007582 600006506
heres another place to look
https://ca.pcpartpicker.com/products/case/#B=1
Edited by thrasher_565
