Is my graphics card dead or is it just my monitor?
Solved by tomcer2003,
21 minutes ago, LulzLaw said:Didn't happen on the other monitors - regardless of the port.
I'm using a RTX 2080S
Currently i have no problems but i havent shut down my computer since. The problems only appear when i boot up windows and 10ish minutes later its gone. Sometimes my monitor flickers black for a fraction of a second
so its monitor, maybe some of capacitors are gone. this would explain the issue. try to check it and replace it
