I had fun building it..
it was cheap (cheappy) but it was worth it
took a lot of planning for a newbie like me
i just hope you guys will like it
I would be happy to get some suggestion and comments..
Parts list:
Aerocool QS-202
Amd fm1 A8-3870K
Gigabyte A75-S2v
Amd entertainment editon 4gb ram
Sapphire HD6950
Seagate 1TB ]
WD 250 Gb for my games
Corsair 60gb force gt ssd boot drive
Huntkey jumper 550watts
modified corsair H60 with FTW res
two corsair SP120's
anted 140cm fan
the test fit...
removed some hdd bays to give way to my gpu
some sleeving...
for me this was the fun part, testing the gpu and it was my firs time to use an SSD
placing the SSD
this was the biggest challenge
making my H60 something special
finding a way where i can set the tubes to shortest way as possible..
THE TEST!!!!!
I thought it will be leaking a lot since I used cable ties to hold the tube on the pump and rad
almost there.. this was the run after the leaktest...
after two hours of testing
this it the finished build
i hope you guys like it
thanks for viewing
https://linustechtips.com/topic/13202-project-cheappy/
Nice work on modding the H60!
| Case: Cooler Master Sniper Black | CPU: i7-3770k @ 4.5GHz | Motherboard: MSI Z77A-GD65 | Video: 2x EVGA GTX680 Classified SLI | RAM: 16GB G-Skill Sniper 1866 |
Drives: OWC Electra 60GB SSD, Crucial M4 128GB SSD, 2x WD Black 500GB, WD Black 640GB | Cooling: H100i w/ 2 Noctua NF-F12s push | Sound: ASUS Xonar DX 7.1 |
| Power Supply: Corsair TX750 |
https://linustechtips.com/topic/13202-project-cheappy/#findComment-141455
Nice job, but I really think you should have stuck with blue to fit the case/mobo. Still a well thought out build
Corsair 600T White | Gigabyte Z77-UD3H | Intel Core i5-2500k | 8GB Gskill Ares@1600MHz | Gigabyte G1 GTX970 | OCZ ZT 550 | Western Digital Caviar Blue 500GB | Western Digital Caviar Black 1TB | Samsung 840 EVO 250GB (boot) | Full Custom Loop | NZXT HUE
https://linustechtips.com/topic/13202-project-cheappy/#findComment-141485
Never thought I would see a modded H60 awesome! Nice work on the sleeving as well :)
Red white and blue f*ck yea! Murcia pew pew pew pew pew pew pew pew
Join the LinusTechTips Star Citizen Org :D ~ https://robertsspaceindustries.com/orgs/UOLTT
https://linustechtips.com/topic/13202-project-cheappy/#findComment-141502
In awe over that H60. Also I really like your SSD placement and some of those heatshrink-less cables
https://linustechtips.com/topic/13202-project-cheappy/#findComment-141781
Nice build, awesome to see that personal touch on the h80. Great choice of hardware. Btw did you notice any difference in performance on the H80?
Mobo: Asus Maximus Impact VI Processor: Intel 4690K @ 4.4Ghz 1.22Vlts Memory: 2x8 GB DDR3 1866Mhz GSkill Sniper
VGA: Sapphire HD 7970 3GB OC Audio: Asus Impact Supreme FX SSD: Mushkin Chronos 120GB HDD: WD Black 500GB
Power Supply: Coolermaster V650 Semi Modular Case: Bitfenix Prodigy Cooling: Corsair H100i
https://linustechtips.com/topic/13202-project-cheappy/#findComment-143120
Hi guys!!!, huge thanks for the compliments...
The h60 performed better after the mod
stock h60 temp:
82 degrees celcious after running IntelBurn in test @high
after h60 modification:
67 degrees celcious after running IntelBurn In test TWICE!! one after the other@high :D
it was a farely good result, so i don't regret what i did to my h60
"maybe because there was such amount of water added to the system that made temps lower...." :)
i had the h60 running for about 3hours before i installed it to my system,,
https://linustechtips.com/topic/13202-project-cheappy/#findComment-143194
