Noob C# Help
Go to solution Solved by xXxYOLOxSWAGxXx_420BlazeIt,
Thank you, just a few questions, would "dongus(55,4) be? Due to it being a fight it would probably a boolean for victory or loss right?
In my example I used a method that took two integers as its parameters, and returned an integer. You can use any mixture of any data types you want.
Dongus can be replaced by any name for the method you would like.
How can I store code, I need to be able to use a "while" loop for a fight scene a lot of times and I don't want to have to copy and paste it so many times. I am at school, and I can't use anything else than IE right now so I can't paste the code or a link to the code so just imagine a few (like 30) lines of code that needs to be used a lot of times.
Intel i7-3770k @ 4.5 GHz                               DCUII GTX 680                            16GB Corsair Vengeance RAM
Sabertooth Z77 ATX                                      WD Caviar Blue 500GB+ 1TB      Corsair Obsidian 750D
Corsair TX850M Watt PSU                            Bad Custom Water Cooling          Samsung 840 Pro SSD
https://linustechtips.com/topic/131997-noob-c-help/
Put it in a method and just call that method where you need it.
public int dongus(int num1, int num2){     int num3 = 0;     while(num1 > num2){         num3+= num2;     }     return num3;}
Then later on in your code you can just do:
int whatever = dongus(55, 4);
https://linustechtips.com/topic/131997-noob-c-help/#findComment-1756522
^ this, it is probably going to be the most efficient in your case
https://linustechtips.com/topic/131997-noob-c-help/#findComment-1756528
https://linustechtips.com/topic/131997-noob-c-help/#findComment-1756552
https://linustechtips.com/topic/131997-noob-c-help/#findComment-1756567
okay, great. Thank you very much.
https://linustechtips.com/topic/131997-noob-c-help/#findComment-1756579
