Non damaging way to mount acoustic foam
14 minutes ago, Janettebot said:Hello, recently I have been looking into getting a nice mic setup and I've come to the realisation that my room is not treated very well at all ( only a bet and curtains, both of which are on the same wall ) and the wall my desk is on is opposite a near blank wall and I need a non damaging way to mount acoustic foam to prevent echo. Any feedback is appreciated and thanks in advance : )
The two non damaging things for wall mounting I know of are blue yak and command adhesive. Blue tac was once called poster putty. It has extremely limited holding capacity, and command adhesive requires that its tab be accessible when mounted so that it can be grabbed and pulled to release it. Command adhesive can stretch a foot or more when being removed and if it breaks during the removal process it can be a real PITA. One would assume what you would have to do is attach the sound absorbent material to a tile of some sort and then mount the tile to the wall using one of the two substances.
