How long is a consumer UPS good for?
True
was going over my hardware and realized I hav't changed out my UPS in a LONG time..   The app for it says everything fine and I have had 10 sec power outage recently so i know its still working.  But i swear i normally only got 3-4 years out of my previous ones and i am pretty sure this ones at 10+ years old.     Note  that where i used to live i lost power due to some dumb ass hitting a power pole at least 7-10+ times a year.  Not an issue where i live now but i am pretty sure i got this UPS maybe a year or 2 after I moved here.
Most power supplies are life limited by the battery.  Once the capacity drops it won't be good to maintain power on its own.
The batteries can be replaced but it's a good idea to test the system capacity as per the manufacturers instructions or DIY a load test.
If properly maintained, they will last.
ya i did the test again last night came back clean..
For me, if it works, it works. Have you had to replace the batteries doing that time?
My APC Smart-UPS Pro says to replace the battery every 3 years.
PC #1 : Gigabyte Z170XP-SLI | i7-7700 | Cryorig C7 Cu | 32GB DDR4-2400 | LSI SAS 9211-8i | 240GB NVMe M.2 PCIe PNY CS2030 | SSD&HDDs 59.5TB total | Quantum LTO5 HH SAS drive | GC-Alpine Ridge | Corsair HX750i | Cooler Master Stacker STC-T01 | ASUS TUF Gaming VG27AQ 2560x1440 @ 60 Hz (plugged HDMI port, shared with PC #2) | Win10
PC #2 : Gigabyte MW70-3S0 | 2x E5-2689 v4 | 2x Intel BXSTS200C | 32GB DDR4-2400 ECC Reg | MSI RTX 3080 Ti Suprim X | 2x 1TB SSD SATA Samsung 870 EVO | Corsair AX1600i | Lian Li PC-A77 | ASUS TUF Gaming VG27AQ 2560x1440 @ 144 Hz (plugged DP port, shared with PC #1) | Win10
PC #3 : Mini PC Zotac 4K | Celeron N3150 | 8GB DDR3L 1600 | 250GB M.2 SATA WD Blue | Sound Blaster X-Fi Surround 5.1 Pro USB | Samsung Blu-ray writer USB | Genius SP-HF1800A | TV Panasonic TX-40DX600E UltraHD | Win10
PC #4 : ASUS P2B-F | PIII 500MHz | 512MB SDR 100 | Leadtek WinFast GeForce 256 SDR 32MB | 2x Guillemot Maxi Gamer 3D² 8MB in SLI | Creative Sound Blaster AWE64 ISA | 80GB HDD UATA | Fortron/Source FSP235-60GI | Zalman R1 | DELL E151FP 15" TFT 1024x768 | Win98SE
Laptop : Lenovo ThinkPad T460p | i7-6700HQ | 16GB DDR4 2133 | GeForce 940MX | 240GB SSD PNY CS900 | 14" IPS 1920x1080 | Win11
PC tablet : Fujitsu Point 1600 | PMMX 166MHz | 160MB EDO | 20GB HDD UATA | external floppy drive | 10.4" DSTN 800x600 touchscreen | AGFA SnapScan 1212u blue | Win98SE
Laptop collection #1 : IBM ThinkPad 340CSE | 486SLC2 66MHz | 12MB RAM | 360MB IDE | internal floppy drive | 10.4" DSTN 640x480 256 color | Win3.1 with MS-DOS 6.22
Laptop collection #2 : IBM ThinkPad 380E | PMMX 150MHz | 80MB EDO | NeoMagic MagicGraph128XD | 2.1GB IDE | internal floppy drive | internal CD-ROM drive | Intel PRO/100 Mobile PCMCIA | 12.1" FRSTN 800x600 16-bit color | Win98
Laptop collection #3 : Toshiba T2130CS | 486DX4 75MHz | 32MB EDO | 520MB IDE | internal floppy drive | 10.4" STN 640x480 256 color | Win3.1 with MS-DOS 6.22
And 6 others computers (Intel Compute Stick x5-Z8330, Giada Slim N10 WinXP, 2 Apple classic and 2 PC pocket WinCE)
-> Moved to Power Supplies
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
If it is a 10 year old SLA battery it will be stuffed. Typically they have a useable life of 3-5 years. Some will go longer but it's a case of pre-emptive replacement for battery backup applications. Don't want to find out it's stuffed when you need it most.
A lot of that age are either vented/bulging or dried out when I find them.
Testing, charging and protection circuits can vary widely in how effective they are. Some will actually periodically load test the battery and have sophisticated charging circuits.  Others may basically just check for voltage and more or less trickle charge it. Have seen shorted or batteries with a dropped cell overheat charging circuits and other issues...
A lot can depend on how hard a life the battery has had, constant deep discharges aren't great for long life, neither is high temperatures and also the charging method and float/trickle charging used.
