Is it a wifi adapter pcie card/usb or is it build into the motherboard? Where did you get the drivers? Just through Windows update or did you manually install the current ones from the motherboard manufacturer support page? If you got them from Windows Update they're likely out of date or just basic drivers.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
What motherboard? Did you reinstall windows? Where did you download the drivers from?
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
what wifi version is your router and what wifi version is your new mainboard, you might have to reduce compability on the board wifi driver to get a stabile connection.
hence wifi 5 wifi 6 wifi 7 etc.. you can lock a higher wifi driver to a lower setting if your router is lower, your mainboard driver will try to connect to the faster, and cause instabilities. just remember to change it if you upgrade to a faster router 😄
Edit: your board is wifi 6.. 802.11ax, wifi 5 is 802.11ac depending on your wifi network router you might have to set the driver to use only 802.11ac
