help ! HELP! Extremly hot CPU 102,5°C
Solved by Darkslyr,
HWinfo displayed a max CPU temprature of 102,5°C! I have a Ryzen 5 3600xt and a stock cooler on top of it with the pre-applied thermal paste. My case is a be quiet pure base 500 which came with 2 pre-installed fans.
Any thing I can do to lower the temperature? I dont want my cpu to die.
ShadeBorderlands ·
Fankywanky ·
Posted in General Discussion1 -
Seosamh_101 ·
Posted in Windows2 -
4
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
