does dvd burn speed effect quality
Solved by PlayStation 2,
It's a multifaceted answer that can be boiled down to a couple of points:
- The disc quality
- The disc burner in question
It's generally in your best interest to burn a disc at one of its recommended speeds, although most modern discs (and disc burners) can generally be burned at faster speeds and still be fine.
To answer your question: DVD burn speed can affect quality if the disc in question is of dubious quality to begin with.
