each cpu is different (even if it is the same model). some cpu can undervolt a lot if you get lucky, while some may not undervolt at all.
what you can do is decrease it a little and test if it still works, then decrease it more and test again. keep going until it stops working. once it doesnt work anymore, increase it more than the lowest you could go (to make sure it is still stable) .
