ram 3000Mhz RAM only runs at 1800 - XMP Does not work, nor does BIOS overclocking.
SOLVED - Thanks for your help!
UPDATE:
I have managed to get all 4 Sticks to 2143 Mhz.
I am pretty happy, and will try to fine tune everything to see how far I can go with it. I jut changed the voltage in the BIOS to 3.5 and manually set the multiplier to 12.33. I hope this will be stable in games and stuff.
UPDATE:
reached 2676 Mhz
UPDATE:
Went full sicko mode and tried 3000Mhz. Works fine (still)
I will do some testing and see if its stable under load.
Thank you all so much for helping me with this! I really thought my motherboard was broken.
This community is amazing!
Could someone tell me if the different RAM kits I have used will cause any trouble in performance? There are only slight differences (I posted the pictures of the SPD Info but here they are again: https://drive.google.com/drive/folders/1-Ar7q1-YfoEfoadRqRmsVA4SlEdo0u5r?usp=sharing )
