Will EVGA accept my warranty for PSU with roaches in it?
Solved by Guest,
Just now, Lerus said:
They're going to see the roaches once they get it and you can't open the PSU to clean it out since that would also void the warranty.
You can't shake out the visible roaches?
The way RMA works: They get the PSU, they test it, they replace it. They don't open them up to inspect for damage, roaches, etc. They only make sure it hasn't been opened and whether it's really dead or not.
