Hello All,
I am having trouble making my subdomain point to the correct IP.
Lets say i have a domain "example.com" which points to 1.2.3.4
What I want to achieve is point my subdomain "sub.example.com" to a different IP e.g 5.6.7.8 . I have successfully done that by pointing the A record of "sub" to the new IP (5.6.7.8).
BUT the problem is that the www.sub.example.com does not point to 5.6.7.8. Is it possible to have the "example.com" and "www.example.com" point to 1.2.3.4 and "sub.example.com" & "www.sub.example.com" point to 5.6.7.8
I have also added an A record "www.sub" to point to 5.6.7.8 but that did not work.
Any ideas?
https://linustechtips.com/topic/1292884-subdomain-help/
You either need an additional A record for your sub-subdomain
www.sub.example.com A 5.6.7.8
or you need to use a wildcard A record
*.sub.example.com A 5.6.7.8
if your DNS provider supports that. In that case you'd then e.g. have an appropriate virtual host on your web server that takes care of serving the appropriate page.
Just be aware that e.g. a wildcard SSL certificate (*.example.com) is not valid for sub-subdomains, so it will not work for www.sub.example.com, only sub.example.com.
https://linustechtips.com/topic/1292884-subdomain-help/#findComment-14384158
Thank you, that helped!
https://linustechtips.com/topic/1292884-subdomain-help/#findComment-14384479
