If i dont overclock my CPU... do i really need a 4 pin cpu power connector?
By
wolfff
in Power Supplies
in Power Supplies
Solved by Eigenvektor,
10 minutes ago, wolfff said:ryzen 5 5600x with a dark rock pro 4 on a b550 mobo
Should be fine. The 8 pin power connector can supply more than enough power. Unless you do extreme overclocking (on LN2) your CPU is not going to draw enough power to require 8+4 pin.
Featured Topics
AccDossNumber15 ·
Posted in Cases and Mods1 -
Splatacake ·
Posted in Peripherals1 -
2
6
MiszS ·
Posted in Operating Systems2 -
vortexx21 ·
11
Elite Knight ·
Posted in CPUs, Motherboards, and Memory15
play_circle_filled
Latest From Linus Tech Tips:
iPhones Are Undeleting Nudes?? - WAN Show May 17, 2024
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
