PSU to MOBO power
Solved by aDoomGuy,
Just now, patken007 said:so i just connect it on the yellow section
This is correct. Just make sure you do not force GPU 8-pin into CPU if they are keyed differently. If you look at yellow section you see some holes are square and some have slightly rounded edges. Your cables should be labeled CPU and GPU as I mentioned.
remo233 ·
Posted in CPUs, Motherboards, and Memory4 -
RTX 3090 ·
Posted in Programs, Apps and Websites1 -
7
6
porina ·
Posted in New Builds and Planning15 -
Rothinsky ·
Posted in Troubleshooting2 -
skayqz ·
Posted in Graphics Cards7 -
Ricodotsh ·
