Behringer Combo is quiet
By
TheFlyingSquirrel
in Audio
in Audio
Solved by The Flying Sloth,
If the mic isn't loud enough for you just get closer to it and increase the gain, so long as you're not clipping you'll be fine.....
If that's not enough gain grab an inline preamp.
kisserik93 ·
Posted in Peripherals4 -
Rick13 ·
Posted in CPUs, Motherboards, and Memory11 -
6
popularlion ·
Posted in Troubleshooting5 -
2
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1
