Question for an electrician
12 hours ago, Lord Vile said:That tells you nothing about what it can drive it's just a layout without an info pertaining to what you're after. You might be able to work it out with the wattage if you know the voltage or current the headphones are taking but other than that it's no use.
We know the impedance of the headphones and can compute the output voltage (roughly) of the amplifier to get a pretty good estimate:
80W into an 8ohm impedance (according to the spec sheet) gives an output voltage of 25.29V (as P = U^2/R)
25.29V into the 600ohm headset impedance gives 640/600 = 1.066W of power. Plenty of power (probably).
Anyway just give it a shot, the impedance of the headphones is much higher than the 8 ohm minimum of the amp so nothing can go wrong.
