2x6 pin to 8 pin pcie
1 minute ago, Rothhaus said:I’ve just seen another post with a similar question and the answer he got was “
it'll be less than ideal, it wont set fire to the cable/connectors/etc, but you will most likely get more voltage drop in the cables, i presume this could result in a slight reduction in power limit, but i assume it will work fine enough.
if you want to play on the safe side, running two 'dedicated' cables will be better, if you can get your hands on an extra cable.”
so what I take from that is that using one 1 2x8 pin cable and another single 8 pin cable can be done but it’s not nearly as good as using 3 separate 8 pin cables.
That lacks context.
You're talking about a graphics card that uses three connectors. That sounds like a post where they were asking about a graphics card that uses two connectors.
Yes... using two connectors on one cable is not ideal in many cases.
I'm guessing you're going to be using an Ampere based card, correct? Keep in mind the Founder's Edition uses only two PCIe on an adapter that converts that to a single 12-pin connection.
The reason the AIB cards have three PCIe is because there's no such thing as a PCIe cable with three PCIe connectors (unless you made one). So by "requiring" three connectors, they're forcing you to use at least two cables.
