Im a Arctic Silver 5 guy.
Main Rig:
Ryzen 5800x, ASUS Crosshair Hero VII Wi-Fi, 32gb of Corsair Vengence Pro SL 3600 CL18, Sapphire Pulse 9060xt 16gb, Noctua NH-D15 LTT Edition, Soundblaster AE-7, Beyerdynamic DT 990 Edition 600 Ohm headphones, 1tb ADATA SX8200 NVME SSD, 1tb Intel 665P NVME SSD, 500gb Samsung 850 EVO SATA SSD, 8tb WB Black SATA HDD, 14tb WD Ultrastar HC530, LG SATA Blue Ray Drive, EVGA 1300w G+ PSU, Coolermaster Stryker case, ROG ARGB strips, China ARGB fans.
HTPC:
Ryzen 5800xt, ASUS B550M Prime Plus WiFi II, 32GB of Corsair LPX 3200 CL16, ASUS 5060 8gb LP, Noctua L9-x65 cooler, WD Black SN770 500gb NVME SSD, WD Black SN770 1tb NVME SSD, Crucial MX500 2tb SATA SSD, WD Blue 2tb SATA HDD, Pioneer Blu-Ray burner, Intel AX200 WiFi/Bluetooth, Seasonic 300w TFX PSU, Silverstone ML11 case.
Retro Gamer PC:
VIA C3 1000Mhz, VIA Epia PD-10000 LVDS, 1gb of Kingston DDR, PNY Geforce FX5500 128mb PCI, WD 80GB HDD, Random CD-ROM, Random 250w mini psu, Mini ITX case 🤣
https://linustechtips.com/topic/1256332-best-thermal-paste/#findComment-14105286
5 minutes ago, Super0609 said:
What is the best thermal paste? I am thinking about changing my thermal paste in my laptop, but i dont know which one is good.
Thermal Grizzly kryonaut.
I used to be, but 1) its conductive which can be an issue for some in certain situations 2) kryonaut is better and isn't conductive, so literally a win win all the way around :)
https://linustechtips.com/topic/1256332-best-thermal-paste/#findComment-14105295
Meh, been out of the PC game long enough to not know a change in the best.
Main Rig:
HTPC:
Retro Gamer PC:
https://linustechtips.com/topic/1256332-best-thermal-paste/#findComment-14105320
I use Artic Silver. But any decent Paste will do.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/1256332-best-thermal-paste/#findComment-14105575
Just throwing this out there.. AS5 is not conductive, it never has been. People must be confusing conductive with capacitive. I use Thermalright TF8, but there is better.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1256332-best-thermal-paste/#findComment-14105966
I switched over to Noctua's NT-H1 and actually saw a -5 degree delta over max temp using NT-H1 when compared to AS5 (In short, 5 degrees C lower using NT-H1 over AS5.
Now I've used AS5 for many years now using the same two tubes I've had and still works just as good, although, it does seem to not perform as well in a MacBook Pro 13 2014 (replaced with NT-H1 and temps lowered as well).
 Very true as stated from the home page for AS5:
Arctic Silver 5 was formulated to conduct heat, not electricity.
(While much safer than electrically conductive silver and copper greases, Arctic Silver 5 should be kept away from electrical traces, pins, and leads. While it is not electrically conductive, the compound is very slightly capacitive and could potentially cause problems if it bridges two close-proximity electrical paths.)
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1256332-best-thermal-paste/#findComment-14105983
It does not really matter. However the best non-metal paste is probably Thermal Grizzly Kryonaut. The difference between the best and the average thermal paste is ~1-2K. That's negligible and within margin of error. A stupid Windows background process can have a bigger impact. See this (older) Tom's Hardware roundup. Heck, even bloody toothpaste was just 10K worse than the best thermal paste.
Bottom line: just use a paste from a reputable brand and stop bothering.
Use the quote function when answering! Mark people directly if you want an answer from them!
https://linustechtips.com/topic/1256332-best-thermal-paste/#findComment-14107810
Between people using too much or too little paste it probably does not matter what the masses run.. people running the best or worst could be getting nearly the same results 🤭
https://linustechtips.com/topic/1256332-best-thermal-paste/#findComment-14108060
