R7-1700 / Gigabyte AB350Gaming.rev1 - G.Skill Aegis 32GB 2x16 3200mhz, machine will not boot with XMP on.
Solved by mariushm,
Make sure the voltage of the ram is set to 1.35v or whatever is required for that frequency.
You could also just try to set manually to 2933 Mhz, 3000 Mhz or something lower than 3200 Mhz ... could be the motherboard is just not quality enough to handle 3200 mhz with those particular sticks... and the first gen Ryzen was also more picky about ram.
