Molex to 6 pin, is it safe?
20 minutes ago, emosun said:yeah , but molex adpaters burn up is the problem
I've never had it happen to me , but what i think has no bearing on the statistic of them melting becuase they are garbage
They will melt if you push too much current, for sure. But a GTX 970 is not going to do that. Especially considering this is a 970 with 2 pcie connectors.
15 minutes ago, mariushm said:That may be, but you have to account for the 3.3v and 5v .... if the psu uses dc-dc converters. then those take 12v from the 12 output to those voltages as needed.
If the pc consumes 30w on 5v and 3.3v, the psu probably used around 32w from 12v to produce those voltages and currents (32w because conversion is not 100% efficient)
Modern PSUs from 2012(ish) on that aren't garbage can output the same power as they're rated for on just the 12V rail.
15 minutes ago, CircleTech said:The worst case scenario is your PSUs OCP doesn't trip and it catches fire, shorts, and takes out the rest of your computer with this.
We're talking about a CX450 PSU here. You're assuming OP has a PSU without OCP (and OP can sue Corsair for damages if it doesn't trip and sets the computer on fire, because it claims OCP and every review of it shows OCP/OPP working).
10 minutes ago, Ankerson said:
It's rated at 40C so there is always that to look at....
And then the adaptors and pushing it toward max capacity.....
Please tell me under what math a 145W Graphics Card is going to push a 450W PSU over max capacity. The second 6-pin connector is completely unnecessary in this GPU.
