ATX Case with 8+ 3.5” bays
79wjd
I’m doing some NAS upgrades and want to either get some rubber HDD mounts or a new case with them built into the bays themselves. I’m currently using a source 210.
 Cheaper is better — the main reason I’m considering a new case is that if I’m already going to be paying for some anti vibration mounting hardware then maybe it makes sense to pay more to get a case with it built in that is also easier to work with (eg drive sleds).
PSU Tier List | CoC
Gaming Build | FreeNAS Server
Define R6 and 7 are the ones that come to mind (whichever is cheaper, currently it seems to be the 7) They're $140 to $170 though AND require purchase of at least 2 more sleds to get up to 8. The Older Define R5 can still be found for about $125 currently on amazon.
Enthoo Pro 2, P500A, P600S all come with 4 Modular HDD bays but can hold up to 8+ (again with separate purchase)
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
Fractal R6 has the room and already setup with rubber grommets.
Comes with 6 3.5" bay "sleds", can order more.
I am sure there are other more dedicated server cases for your needs tho, I just like my R6 :)
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Anything cheaper around worth considering? The R5 was what I was looking at originally, but it’s a bit much to mainly just avoid spending $20 on rubber grommets.
@Dedayog @TVwazhere
PSU Tier List | CoC
Not in my opinion
@Dedayog @TVwazhere
Not really.  You're looking at a substantial amount of drives, and regular cases just don't fit that many comfortably and easily.  You're paying for it.
But you could just lay down a rubber mouse mat of 24x36 inches and then just place the drives on that if you want to go super cheap.
Considering the cost of 8x HDD's of decent size... a $150 case is just a small chunk of the cost.
OnePlus:
Other Tech:
I don’t disagree, but the Source 210 I already have is honestly “good enough”, it was just a thought that it might make sense to spend $70 or something on a nicer case as opposed to “wasting” $20 on grommets.
At $120-170, it’s not really worthwhile.
10 minutes ago, TVwazhere said:
Not in my opinion
Unfortunately that’s what i figured.
PSU Tier List | CoC
  • 2 weeks later...
@Dedayog @TVwazhere Any thoughts on the Antec P101? It seems to have generally good reviews, but I haven't been able to spot a good picture of the caddies indicating if they have any anti-vibration. I can get it for $30 less than an R5.
PSU Tier List | CoC
The vent holes are VERY small on those side vents that are meant for intake, and there only on one side. Airflow wise for your multiple hard drives, you almost may as well have a sealed off front panel.
I'd say the interior is also much worse quality, but seeing as you're using a Source 210 it wont be a downgrade exactly. Personally I'd go with an R5 but in the end it's your decision.
