Internet speed cut in half when 2 users use it
3 minutes ago, SupaKomputa said:Yeah basically if you have 20 devices with 70mbps that's 1400mbps which is unlimited to me.
Now this may happen if the bandwidth limiter happening inside the modem not the ISP server.
Every wifi has it's own bandwidth, lan on the other hand is treated as 1 channel.
I have cable internet 10 years ago and i can hack it so i get more bandwidth because the limit is imposed inside the modem.
No, that's not how it works. If an ISP is giving you X speed you get that across all devices to the outside that's what you get across all devices, wired or wireless. No ISP would ever give you X bandwidth PER device unless you're paying for that rate per device and that's going to be a ton of money. The bandwidth limit happens at the modem/WAN facing router and it rate limits there, it doesn't care how the device is connected. If you're able to adjust your egress bandwidth on the modem your ISP is incompetent and doesn't understand how to secure their devices and firmware.
