I would like to ask a question regarding ethernet specifically in laptops.
Is the ethernet in laptops tied to the wifi card? (if i upgrade the wifi card does that upgrade the ethernet?)
PC: Ryzen 5 2600, 16GB 3200mhz RAM (8GBx2), Gigabyte B550M DS3H, GTX 1050 2GB, 650W Semi-Modular PSU80+ Gold
Phone: Poco F3 8GB + 256GB
Audio: Samson SR850s
Sound Card: SoundBlaster Play 4 USB sound card
IEM: planning to get the KBEAR KS2s
Please be patient with me, I'm fatally dumb and its honestly a miracle I've made it this far
https://linustechtips.com/topic/1239460-ethernet-questions/
No, they are independent. You cannot "upgrade" the ethernet in a laptop.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1239460-ethernet-questions/#findComment-13963241
https://linustechtips.com/topic/1239460-ethernet-questions/#findComment-13963259
2 minutes ago, CWALD said:
The only way to improve your laptop Ethernet is to use an Ethernet to USB 3.x dongle that supports higher speeds.
Soo a dongle that has ethernet?
https://linustechtips.com/topic/1239460-ethernet-questions/#findComment-13963262
Yes. They cost like $7 or less, like e.g. here's a link to one of eBay: https://www.ebay.com/itm/USB3-0-to-10-100-1000-Mbps-Gigabit-RJ45-Ethernet-LAN-Network-Adapter-G0C3/114294364817
https://linustechtips.com/topic/1239460-ethernet-questions/#findComment-13963269
what's the problem with your current ethernet?
____________________________________________________________________________________________________________________________________
pythonmegapixel
into tech, public transport and architecture // amateur programmer // youtuber // beginner photographer
Thanks for reading all this by the way!
By the way, my desktop is a docked laptop. Get over it, No seriously, I have an exterrnal monitor, keyboard, mouse, headset, ethernet and cooling fans all connected. Using it feels no different to a desktop, it works for several hours if the power goes out, and disconnecting just a few cables gives me something I can take on the go. There's enough power for all games I play and it even copes with basic (and some not-so-basic) video editing. Give it a go - you might just love it.
https://linustechtips.com/topic/1239460-ethernet-questions/#findComment-13963280
Dell XPS 15 L502x nearly 9 yrs old thats why im looking to improve ethernet
https://linustechtips.com/topic/1239460-ethernet-questions/#findComment-13963288
3 minutes ago, Biomecanoid said:
You probably won't get a better USB Ethernet than the one already on the motherboard. Unless its broken
what if the one on the motherboard is 9 yrs old?
https://linustechtips.com/topic/1239460-ethernet-questions/#findComment-13963301
Quick question if i do a speed test with ethernet connected (ookla speedtest) it will measure from ethernet right?
https://linustechtips.com/topic/1239460-ethernet-questions/#findComment-13963322
Unless you got very fast speed tour internet connection will most likely be bottleneck before the ethernet.
“Remember to look up at the stars and not down at your feet. Try to make sense of what you see and wonder about what makes the universe exist. Be curious. And however difficult life may seem, there is always something you can do and succeed at.
It matters that you don't just give up.”
-Stephen Hawking
https://linustechtips.com/topic/1239460-ethernet-questions/#findComment-13963675
wha?
https://linustechtips.com/topic/1239460-ethernet-questions/#findComment-13964635
4 hours ago, Hassan170 said:
wha?
In english, you don't need an ethernet dongle.
In real life, I act like I know less about tech than I actually do.
Main build: CPU: AMD Phenom ii X4 955 Black Edition @ 4,0GHz (Cooler Master 212) | GPU: MSI RX580 8Gb | RAM: 12Gb DDR3 | PSU: Chieftec CTB-500S  | Mobo: Asus M4A87TD/USB3 | Storage: Seagate 500Gb HDD
Yes, I'm aware my CPU is a huge bottleneck. No, I don't really care.
Laptop: Asus TUF FX505DT 60Hz 8Gb model
"Fortifications, cannons and foreign aid won't help unless every man knows that he himself is a guardian of his country"
-Carl Gustaf Emil Mannerheim
https://linustechtips.com/topic/1239460-ethernet-questions/#findComment-13964998
No, it will test the connection between your modem/router to Ooklas servers. Your internal network speed makes zero difference to this.
If its a 9 year old laptop then it will be a 100base NIC which will give you somewhere around 10MBps.
Main Rig:-
Server:-
https://linustechtips.com/topic/1239460-ethernet-questions/#findComment-13965017
sooo ethernet dongle yes or no?
https://linustechtips.com/topic/1239460-ethernet-questions/#findComment-13967742
You will see a boost if you have a USB 3.0 port for that USB Ethernet adapter and the onboard ethernet is 100 mbps fast ethernet rather than Gigabit ethernet. Which was common up until the Sandy/Ivy Bridge days.
What can you be doing with a machine that old that requires faster internet?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1239460-ethernet-questions/#findComment-13967753
What?! This is 100% wrong! Of course your LAN-bandwidth matters, like e.g. if your Internet-connection was gigabit, but your LAN was running only at 100Mbps, the maximum Speedtest could give you is 100Mbps!
https://linustechtips.com/topic/1239460-ethernet-questions/#findComment-13967766
What laptop do you have? Does it only have a 10/100 Ethernet or does it have a gigabit Ethernet? If it has gigabit Ethernet, then a dongle would be useless. If it does have a 10/100 Ethernet, then yes, a dongle would be an improvement. Do note, however, that that does not necessarily make your Internet-connection faster: that depends on the rest of your network and the contract you have with your ISP.
https://linustechtips.com/topic/1239460-ethernet-questions/#findComment-13967769
Dell XPS 15 L502x
https://linustechtips.com/topic/1239460-ethernet-questions/#findComment-13967835
30 minutes ago, Hassan170 said:
Dell XPS 15 L502x
That laptop already has gigabit Ethernet, you're not going to get any benefit from a USB-dongle.
https://linustechtips.com/topic/1239460-ethernet-questions/#findComment-13967866
wait it does!? well then why is my internet so slow?
https://linustechtips.com/topic/1239460-ethernet-questions/#findComment-13967871
