4K 144hz + and 40+ inch suggestion
wawamr2
Hello all
With the upcoming of RTX 3000 series, I will update my 1080ti as soon as the 3080ti is available. With that I want to upgrade my monitor too.
Right now I have a ultrawide asus rog 37in 100hz. I want to go 4k, 144hz or more and it need to be big, like 40inches or more because I have a hugh desk computer and the 37in ultrawide is small on the desk (see pic).
I also have a I7-7700k oc at 5ghz. I may need to upgrade too, Will do if needed.
What are your suggestion? Anything under 2000$ canadian?
Thanks
wawa
and also you need to upgrade your CPU. Go with the ryzen 9 3900xt or i9 10990k because it seems you have a lot of bread to spare and also how are you using that mouse on a glass table?
I'd hold off on upgrading the CPU until you notice it's actually a problem. The 7700k is still a capable CPU, plus you have it overlcocked. Moving from 1440p (I assume) ultrawide to 2160p will only push the performance bottleneck more towards the GPU (as in I don't expect to hit 4k 120 Hz in AAA games at max settings still), but who knows maybe I'm wrong). It also depends a lot on what games you play. It'll be more of a bottleneck in CPU bound games than balanced or GPU bound games.
The BFGD monitors sound in your ballpark: 4k 120 Hz and 43" big. I don't think there are any other type of large monitors that have 4k 120+ Hz refresh rate at the moment.
Side note, consider how far away you are from the monitor. It is subjective of course, but I'm using my old 43" 4k TV as a monitor at 60 cm distance currently and I actually find it a bit too big for gaming that way, because I can't see everything at once. That's just personal preference though.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
I'd wait to see what the 3000 series cards can do. Right now it takes dual 2080 Tis to hit 4K @ 144fps. The 3000 series cards will obviously have more power, but based on what's been leaked, I still don't think you're getting there with even a 3090.
CPU: AMD Ryzen 9 5900X · Cooler: Artic Liquid Freezer II 280 · Motherboard: MSI MEG X570 Unify · RAM: G.skill Ripjaws V 2x16GB 3600MHz CL16 (2Rx8) · Graphics Card: ASUS GeForce RTX 3060 Ti TUF Gaming · Boot Drive: 500GB WD Black SN750 M.2 NVMe SSD · Game Drive: 2TB Crucial MX500 SATA SSD · PSU: Corsair White RM850x 850W 80+ Gold · Case: Corsair 4000D Airflow · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: Corsair K100 RGB Optical-Mechanical Gaming Keyboard (OPX Switch) · Mouse: Corsair Ironclaw RGB Wireless Gaming Mouse
I use a mouse pad. Just took it off for picture 😉
Monitor is about a meter away from me. So right now I'm always pulling it closer. That is why I want it bigger. And yes Right now its 1440p ultrawide, so 4k standard wont be much more pixel, except I want higher frame rate.
i9 10900k is it realy needed since I'm only gaming. No video editing and rarely CAD. i7-10700k should be fine?
It actually still is quite a jump. WQHD is 3440x1440 = 4,953,600 pixels. 4K is 3840x2160 = 8,294,400 pixels. That's still a 67% increase, versus the 100% increase over standard 1440p. In other words, it's still a ton of additional pixels to drive.
Ah yeah, 43" sounds good at 1m away.
Don't underestimate the amount of pixels compared to ultra wide though!
^ This. It's quite a jump to 4k. Even a 2080 Ti SLI can hit 120+ FPS only in a handful of games so far, so it'll probably still require 3080 Ti SLI to comfortably hit 120+ FPS in graphically intensive AAA titles.
I'm also a big fan of 120 Hz though and even on desktop prefer it over 60.
I would honestly just stick with your 7700k for now. You can always upgrade it later if you notice it's strongly holding you back.
It's worth mentioning that DLSS on the Nvidia cards goes a long way towards enabling "4K gaming". It's not true 4K as you're still running 1440p or 1080p, but the 4K upscaling is almost good enough that you wouldn't know the difference, especially with DLSS 3.0. The caveat is that not all games support DLSS, but for those that do, you can basically get the 4K at 144fps experience you're looking for running at only 1440p or even 1080p, which obviously puts a lot less stress on the card.
On 8/20/2020 at 1:55 PM, wawamr2 said:
Hello all
Thanks
wawa
Hows 120hz 4k 48" sound ?  Oh and its OLED so ull never want to go back to a LCD monitor again :P
LG CX 48".
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
On 8/20/2020 at 10:43 AM, wawamr2 said:
10700k will be fine, if you are going over 40 inch oled 120hz would be my pick, only reason to pick a LCD imho is the smaller size, PG43uq is ok, XG has panel issues.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
LG CX 48".
This is literally your best option since you have that budget.
LG CX 48".
That was a very good option, but.. it is cancel in Canada :(
Not a lot of option so far. Only Asus ROG PG43UQ
LG CX 48” is what I would go for tbh,
Is there any way you can get it from Amazon/USA?
Has to be a way!
Or C9 55” if it’s not too big.
You can get monitors bigger, but no where near the picture quality.
  • 1 month later...
Well LG will send CX 48 to Canada finally in november. I just pre-order one. Thanks all for the suggestion. All the comments and the reviews I have watch confirm what you guys told me.
Now if only I can find a RTX 3090!!
Thanks
wawa
