Can I use AC power cord of Seasonic PSU with Corsair PSU
MS14
Turns out, AC cord of my new Corsair TX650m PSU can not fit into any wall sockets or in my UPS socket. But I still have my old Seasonic S12ii PSU. Can I use its AC cord with Corsair one? Will it be safe for my other components & the PSU itself? If not, what are my other options now?
if u meant these
Power Cord, Computer Power Cable, PC Power Supply Cables & Cords ...
then yes
-sigh- feeling like I'm being too negative lately
AC cords simply carry a direct power signal, they don't do anything to it, or are a safety mechanism, as long as the prongs fit they work. The actual PSU block takes care of all the important things like voltages and surges.
I also lack post processing when I post so please refresh before replying as I probably edited my response!
Quote me if you want a reply! :)
Moved to Cases & Power Supplies.
The AC power cord uses a standard C13 connector, so yes you can use the power cord from the Seasonic PSU.
Why doesn't it fit? Is it the wrong plug type for your country? It should include include the cable for the region it is sold in. If it didn't include the right cable you should be talking to the store you bought it from.
They sent me the cable with UK plug where as I am in India. I am not the only one, for some reason, corsair does not put Indian socket compatible plug at all, regardless of where we buy it from . I will send them an email soon as well. They also had a warning label on the plug that said if the plug is unsuitable for available socket, we should cut it off & replace it with another plug with 13 AMP rated fuse.
that doesnt sound like a proper advice that a company should give
is the sticker from the retailer or?
1 minute ago, MS14 said:
Its from Corsair itself.
geez... they should supply u with the right cable if you ask one from them anyways.
i dont recommend changing a socket head unless you're comfortable with it
I would not be changing it, maybe I will use an adapter instead. I will definitely contact corsair & ask them for a replacement cord. Doubt they will do anything though, since it is a known problem. Amazon is full of people complaining about this.
in any case, you'll be fine with using the other cord
