raspberrypi4 RasspberryPi 4b not connecting to wifi
Solved by Madmadz16,
On 5/17/2024 at 5:38 PM, Madmadz16 said:I'm going to use it for pihole and I'll do some more testing when I get back home
Ok so I just got back and was able to do some more testing and now it just worked...
I removed the one that had the static ip set and rebooted and it stayed connected, then I set a static ip and rebooted again and it just worked.
