Motherboard connector part numbers
Solved by Poinkachu,
2 hours ago, salair54 said:Thank you!
I'm guessing that Molex KK and these HU/WF connectors (and this clone I'm interested in) might not be interchangeable... That would be a shame
This is the clone I'm looking at
The 1st link, so many variations, no idea which one you meant.
The 2nd link might, at the very least when the key guard (no idea what it's actually called, that 2 raised section on it's edges)
Same pitch size, 2.54mm
The way I see it, as long the pitch size is the same, and the female pin inside can accept and hold the male pin then it just a matter of making sure the polarity guard fits somehow.
But yeah, that's a conjecture based on theory based on looking at just pic. I wouldn't know for sure unless I have the item
