Linux doesn't recognize my external usb sound card?
y0ur5h4d0w
hey guys, i'm running KDE Neon on my thinkpad T61 (reeeeeally old laptop), i'm using it to record my band sessions using the software REAPER by cockos so i can then extract the tracks i need... the problem is that my tascam us-800 is NOT recognized by reaper and somehow i can't see any of the 6 inputs while on windows it should work fine... what can i do to solve the problem?
Metalhead with a huge itch for PC gaming, video editing and audio recording, currently playing in a band and pwning n00bs in the summoners rift ;)
20 minutes ago, y0ur5h4d0w said:
KDE Neon
Are there native drivers for your hardware available?
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
i've searched on google and ppl said that this specific card works without drivers on linux, though, they were all old threads (like from 2018 the latest) is there any way to fetch drivers from the terminal?
EDIT: on the tascam product page there's only drivers for Windows and MacOS
You can force drivers via terminal, but you have to find the repository first, and that's usually kept on the manufacturer's website, if they aren't listing any drivers, it's *possible* they pulled support for it under *nix.
I'd write them an e.mail and ask...
i was going to actually... though if i open a ticket they ask for an OS and there's no Linux... i guess there's literally no support for linux... i might be stuck on windows 😕
Worst they can say is "Begone with your lame n00b OS and wimpy metal chords, only the true OS and Bathory fans may use our products! Muhahahahaaha!"
I mean, worst they can say is the product is no longer supported under *nix.
You still might find an old repository floating somewhere on the 'net tho.
soooo i managed to make everything ALMOST work, i've swapped from KDA Neon to manjaro 20.xx (latest version from the official website)... now i need to understand why ALSA is capturing my internal laptop microphone instead of my sound card even though in JACK the settings is set to ALSA as driver with my soundcard as interface and i've even used the command "jackd -R -d alsa" to make the jack server work in realtime!
though, when i start the software REAPER, i get only 2 channels working out of a total of 6 (+2 midi)
Post this in the linux section,
They will know a lot more about using a silly OS than us Audio chads.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
