Usually, but it depends on how it was done.  There is underclocking and undervolting.  One can sometimes lower voltag while overclocking and get the same speed with reduced power use.  Generally needs an unusually good chip.  Sometimes it works on most chips of a given type or most chips of a given type on a given motherboard though.  Depends on instance.  For example I understand on 3600 CPUs undervolting works unusually well depending on maybe motherboard or bios or something
I just set the power limit in MSI Afterburner.
I don’t know enough about afterburner you know if it’s possible in that app.  usually getting it to work is even more ticklish than an overclock.  Advice Would need specific model of card and I still wouldn’t be able to give it.  Someone else here might though.
msi mpg z390m gaming edge ac
i5 8400
asus gtx 1070 turbo
and Afterburner seems to lower GPU usage in taskmanager 'Copy' section to around 80%
2 hours ago, Nine Tailed Fox said:
I have mine set to 93 vs. 100 as full power seems to make my GPU too hot and easily go 80-85C but 93 power level makes it a manageable 70-72C. Folding PPD would obviously take a hit right?
I'm not an expert far from it but I can tell you my results. I am running 2 RTX 2060 and I set them to 80% power limit with Afterburner. The power draw on the cards dropped from 160W down to around 130W and lowered the temps quite a bit top card is at 65C lower card at 60. As far as I can tell it has had negligible impact on PPD.
My goal is to one day get a Gold badge on this 1070..
ITNOS runs two 1070ti's at only 60% power draw, but are both OC'd +150mhz so they run at around 1800-1900mhz all while at or under 60ºC. Power draw is reduce by about 30% but PPD is reduced only about 10% compared to "Stock" or OC'd levels. MSI afterburner was used to set the power limits.
  • 2 weeks later...
I’m currently running 5 2070 Supers, a 2070A, a 2060 Super, a 2060 and a 1660Ti all at the lowest possible power limits. I’m also running them only during the least expensive time-of-use period for electricity (19:00-07:00) to minimize the cost and limit the heat load during the AC season here (Ontario). Nets me about 8MPPD on weekdays and ~15MPPD on weekends. I’d estimate they’re producing about 15-20% less PPD at about 30-40% less power.
I’ve 3 1060 6GBs, 2 Rx5700XTs and a 1070Ti sitting idle until the temperatures cool. Turing is just so much more efficient than Pascal and the AMD cards are a PITA to tune in Linux.
6 GPU Folding Rig  Linux Folding HOWTO Folding Remote Access Folding GPU Profiling ToU Scheduling UPS
Systems:
desktop: Lian-Li O11 Air Mini; Asus ProArt x670e WiFi; Ryzen 9 7950x; EVGA 240 CLC; 2 x 48GB DDR5-6000; 2 x Samsung 980 Pro 500GB PCIe3 NVMe; 2 x 8TB NAS; MSI RTX 4070 ti Super; AMD FirePro W4100; Corsair SFF750
nas1: Fractal Node 804; SuperMicro X10sl7-f; Xeon e3-1231v3; 4 x 8GB DDR3-1666 ECC; 2 x 250GB Samsung EVO Pro SSD; 7 x 4TB Seagate NAS; Corsair HX650i
nas2: Synology DS-123j; 2 x 6TB WD Red Plus NAS
nas3: Synology DS-224+; 2 x 12TB Seagate NAS
dcn01: Fractal Pop Silent XL; Gigabyte Aorus z570 Master; Ryzen 9 3950x; AMD Wraith; 2 x 16GB DDR4-3200; 256GB NVMe; Gigabyte Gaming RTX 4080 Super; MSI 4070 Ti Super Gaming X; Corsair RM750e
dcn04: Fractal Define S; Gigabyte Aorus ax570 Master; Ryzen 9 5950x; BeQuiet! PureRock 2; 2 x 16GB DDR4-3200; 250GB NVMe; ; Gigabyte Gaming RTX 4080 Super; MSI 4070 Ti Super Ventus 2; Corsair TX750M
On 8/3/2020 at 6:00 AM, LazyDev said:
I may have to explore the power limit with my 2070, unless I can find a way to cool that GPU.
Or manually set the fans to 10-15% above where they’re sitting now
Systems:
