needing a cheap sound card because my onboard actually sucks
hoggydoggy
I'm using a sorta old lenovo motherboard and I find things very quiet and not great quality, I actually get better sound quality from my S3.
I simply need a sound card for £20 ≈ $30 or less. just something which will work and give me better audio quality.
what I mean by bad audio quality is all sounds sound very hollow and at max volume is what I would consider low-medium sound level
xonar dg?
| i5 4690K 4,4Ghz | Gtx 680 Msi twin frozr Oc edition | Kingston HyperX 2 x 4 Gb | Asus Z97-A | Seagate Barracuda 1 TB| Samsung 840 EVO SSD 120GB | Fractal Design Integra 750 W | All gently placed with great fright inside a Fractal Design Define R4 |
| ProJect Head Box S USB with Hifiman HE-400's plugged in | Check profile page for more Audio shizzle(dizzle) |
xonar dg?
I was looking at that but because I'm not exactly an audio guy, I wanted to check here first
Check if you have a PCI-Slot for the Xonar DG. Otherwise you'll need a Xonar DGX (essentially the same card, but with PCI-E Connector)
  • Primary PC: i7-3770K@4,6GHz | Thermalright Macho | ASRock Z77 Extreme 4 | 16 GB Corsair Vengeance@1866MHz | 2x Gigabyte 660ti 3GB@1130MHz | 256 GB Samsung 840 | WD Black 1TB | BeQuiet! DarkPower Pro 650W | Zalman Z11
  • Secondary PC: i7-860@3,1GHz | Scythe Katana 3 | ASUS Maximus III Formula P55 | 8GB Corsair Vengeance 1600MHz | 2x Zotac GTX 280@650MHz | WD Velociraptor 500GB | Seagate Barracuda 2TB | BeQuiet! DarkPower Pro 750W | Coolermaster Cosmos S
I'm running a Xonar DG. It solved most of my audio issues, and it didn't cost too much. If your onboard is really bad (or really hiss-y) I can recommend it.
Please check that you have a PCI slot for it, as Hyrikan said :)
"PSU brands are meaningless, look up the OEM."
not "essentially" but rather "literally"  ;)
thanks I'll be buying the Xonar DGX once I'm less broke sometime next week
No no no, they changed like ... a capacitor :D.
