For perfomance , mATX vs ATX,is there a difference?
opinions do not equal facts. I stand by everything I said.
but I am glad some people agree with you.
however, if I was going to spend 2k-3k for a no compromise pc for the best frame rates.
i would not put a high end graphic card (if it will even fit) nto a small form factor where there is little air it can move and will throttle if it can not be cooled.lso almost all matx and small form factor motherboard have two memory slots. if i was to select a motherboard that required heavily multi tasking where i knew i might want to upgrade memory later i would not select a motherboard with just two slots available.
also as i mention, alot of matx mb manufacturers make compromises for the size of the board and one of the common things is not being to put as good audio chipset. most people do not have a dedicated audio card and it would be surprising the difference in terms of sounds of games which have been more cinematic feel.
I also mentioned less m.2 slots and sata connectors etc. none of this is factually incorrect.
i admit there is a vocal small form factor community i get that, and I own one myself as a home theatre/general gaming pc.
it is not the best option for her use case and requirements who want ultimate performance. its just a fact mb make compromises on these boards to cram things into such a small space
Is there a big difference these days in mATX and ATX?
14 members have voted
1. Is there a big difference these days in mATX and ATX?
Yes ofc! Better Overclocking, power delivery etc!2
No, ofc not, the designs of the PCB's are equal, only if you need to run more expansion cards I.e. if you need more than 3 PCIe slots12
This poll is closed to new votes
- Prev
- 1
- 2
- 3
- Next
- Page 1 of 3
- Prev
- 1
- 2
- 3
- Next
- Page 1 of 3
