Cpu Fan Upgrade or Case Fan Upgrade
Solved by _sirhC_,
Hey,so after you guys recommending it to me I ordered the arctic cooler 34 esport duo and its way better than expected. I am currently at 3.9ghz at 1.25V stable and when both the GPU and CPU being stress tested and heat is being pumped my temps are very very good. My CPU never goes above 65C , GPU(70-75C). While the fans do have a bit of sound , not much but noticable(with headphones off). It performs perfectly so i recommend it if anyone is looking for a budget option.
So thanks guys for helping me out.
@Stahlmann98 @TVwazhere @HairlessMonkeyBoy
