Help me guys! spilled water on gpu
maniey
i do the water water cooled system on my pc..but while in leak test phase(pc turn off plug pulled out) i forgot to cap my gpu water block on the other side..the water come out but ill stop the pump real quick,,
it spill a bit but not too much but i believe some water go through the pcb and back plate..i use hair dryer to dry it up, my gpu layout is vertical
i just dont want remove the loop again because its all already tighten plus im using hard line loop
so my question here
1.how long it can be safely turn on without remove my loop?
2.do i need open the gpu to clean pcie slot?(its gonna be hard) :(
3.any other quick way to make sure im safe to turn on..i dont wanna waste my GPU :(
This is the risk you take when water cooling, gonna have to bite the bullet and open it up and check everything, better be safe than sorry.
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
does Distilled water still damaging the pcb in turned off?
Doesnt damage if not powered on.
My Rig
CPU - Ryzen 5 1600@3.8ghz          GPU - XFX XXX RX580 8g          Cooler - Arctic Freezer 33 eSports edition green          Motherboard - Gigabyte AB350 Gaming 3          Ram -  G.Skill 2x8 Ripjaws 5 2666                   Case - Pahntecs P400s TGE Modded with Green accents          PSU - Seasonic M1211 evo 620w          SSD - Samsung 960 evo 500 GB          HDD - Seagate Barracuda 7200rpm 2tb
 Fans - 2 be quiet SilentWings 3         OS - Windows 10 Home 64-Bit         Cables - Cable Mod Green Cable Extension
 Peripherals
Mouse - Logitech G502          Keyboard - k95 Platinum Brown          Headset - Philips SHP9500s + Vmoda Boom Pro          Monitor - LG 29UM69GB
Webcam - USB webcam for Wii Fitness game xD
and does my hair dryer do the job?
Maybe but you should let it dry afterwards for a day or two.
My Rig
 Peripherals
so the conclusion is i cant turned the pc today and still need those 2 days even i clean using blower...right
For me I would use alcohol to remove any water or left over particulates .  At 5 minute Linus explain it
waters tricky, give it a few days and hope it doesnt corrode anything, or open it up and let it dry and put it back together in a few hours
AMD blackout rig
Distilled water isn't conductive,but it tends to absorb stuff into it like salts and minerals,and then becomes conductive.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R23: 15669cb | Unigine Superposition 1080p Extreme: 3566
thanks guys..but time really killing me
7 minutes ago, Beowulff83 said:
If your going to let it sit. Open it up and set a box fan in front of it.
how long it will dry up everything?
You could use alcohol as one person said
My Rig
 Peripherals
so my question here
guys what the worse outcome if i try turn it on today after blow hairdryer and put some stand fan toward the gpu side?
Water is still left there and rip GPU.
My Rig
 Peripherals
lol
