Help me with 3900x High Temps
pathikrit
I am getting high temps at idle around 50-60c. I am running everything on Stock and using included AMD Wraith Prism Cooler.
Can someone help me with what settings I should go with to get optimal performance and lower temps. Also any AIO suggestion
My Build -
AMD 3900x
Gigabyte Aorus x570 Elite
16x1 3600mhz {will increase as rightnow not in stock because of COVID}
Gigabyte Aorus P750W
RTX 2070 Super
NZXT H510 Elite Case
Main Focus of my build is Premiere Pro and After Effects and some casual AAA gaming.
Don't double post, people are commenting on your original post.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
Get an aftermarket cooler, the minimum would be a Hyper 212 Evo, but get something in the ~$70 range.
Sorry for the double post, will keep not to do the same in future
15 minutes ago, pathikrit said:
AMD Wraith Cooler.
I'm sorry a wraith cooler for a 3900x?! Well there is your problem 😉
Just get a better cooler
Phone: Pixel 3a (Purple-ish).
Build Log:
