GTX 1650 for recording/streaming through capture card
Solved by Haro,
5 minutes ago, CrisR82 said:So instead of that, I just wanted to know how far I can push this one and leave it be, then later down the line grab a new one and leave this as a backup or non-gaming/video editing tasks.
The best that can get with this is a 1650
I think it'll be able to handle 60 fps no problem
And I don't recommend a PSU either way
Because if it's an oem build like a Dell optiplex , while they look standard with normal mobos and psus ( even though it's janky ) they usually have different pin layouts and could cause a short and it'll make more problems that it will fix
