I can made side panel fully transparent?
ZowieR
My case: Antec GX300
it was transparent but I want fully transparent.. and maybe doing it glass..
it was possible? expensive or cheap?
You mean it’s translucent. And what it transparent.
Id guess you’d need to see how it’s shaped and try to get something to mimic that. Order a piece of tempered and double side tape it.
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
many ways of doing it . plexiglass, glass, lexan other plastic. mnpctech on youtube has all the ways of cutting and mounting a window with
drilling holes, dermal, jigsaw, scroll saw, saw all... soon to come nibbler....axe, chane saw.... ok last 4 might not be a thing...
and mount with.nuts, rivets, double sided tape. wood glue, hot glue, gorilla glue, super glue, gum....im kidding
glass would be a bit more difficult but doable.
Browne points for thows that no about the duel channel u channel way!
20180402%20%20Glazed%20channel%20Rubber%
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
