Hello all!
I was just wondering your opinion on my OC.
Is it good for my CPU? (8320)
I didn't end up hitting a voltage cap, but rather a temp cap (70C in Synthetic benchmarks [prime95])
I got up to 4.414 Ghz, [Mult:20, Bus:220]  Voltage is at 1.404 V
Does all look good, or is something a little to inflated?
Is the temp normal, or does it seem to be really hot? (Looks pretty normal to me, but I'm naive.)
Case: Lian Li PC011-D - CPU: 3900x - GPU: 2080ti Reference - Mobo: Gigabyte - Ram: Corsair 4x16gb 3200MHz - SSD: 2TB Samsung Evo NVME
https://linustechtips.com/topic/117753-hows-my-overclock/
Your times are fine. 70c is pretty good.
                    Fractal Design Arc Midi R2 | Intel Core i7 4790k | Gigabyte GA-Z97X-Gaming GT                              Notebook: Dell XPS 13
                 16GB Kingston HyperX Fury | 2x Asus GeForce GTX 680 OC SLI | Corsair H60 2013
           Seasonic Platinum 1050W | 2x Samsung 840 EVO 250GB RAID 0 | WD 1TB & 2TB Green                                 dat 1080p-ness
https://linustechtips.com/topic/117753-hows-my-overclock/#findComment-1570708
Hello all!
Tmax is 90 (70 coretemp on cores) but they start to throttle at 65. So try keeping your temps below that. Have you turned off all the BIOS functionality (cool n quiet etc.?)
AMD FX-8350 @ 4.7Ghz when gaming | MSI 990FXA-GD80 v2 | Swiftech H220 | Sapphire Radeon HD 7950  +  XFX Radeon 7950 | 8 Gigs of Crucial Ballistix Tracers | 140 GB Raptor X | 1 TB WD Blue | 250 GB Samsung Pro SSD | 120 GB Samsung SSD | 750 Watt Antec HCG PSU | Corsair C70 Mil Green
https://linustechtips.com/topic/117753-hows-my-overclock/#findComment-1570711
Looks normal.
https://linustechtips.com/topic/117753-hows-my-overclock/#findComment-1570746
Yeah, it's all off.
70 is under a synthetic bench,
Wouldn't it be lower in actual gaming?
https://linustechtips.com/topic/117753-hows-my-overclock/#findComment-1570751
Also, 70 would be the temp cap that I should push it to, yes/no?
I found that number somewhere in the LTT forums, in a post long buried.
https://linustechtips.com/topic/117753-hows-my-overclock/#findComment-1570756
i've used ASUS CH5FZ guide and push 74-76° with no throttling. ROG is saying that's
a normal overclock temp. i seem to agree as the "actual" temperature isn't known as
most softies miss the sensor address a bit and the readings are all over the place.
the biggest thing i look at is the VRM/MOSFET temperature. usually higher than CPU
and just a important for stability. if you have a fan available, direct it at the VRM/MOSFET.
From ROG: However, you’ll also notice the CPU temperature has increased a lot too; our setup here recorded a delta T of 49°C. This is hot, as expected, but still within the TJMax of the chip though.
https://linustechtips.com/topic/117753-hows-my-overclock/#findComment-1570865
@airdeano
What are you using to monitor your temps? Mine doesn't have VRM/MOSFET temps.
Using HWMonitor, this is what I see
CPU overclock temp
https://linustechtips.com/topic/117753-hows-my-overclock/#findComment-1570946
@airdeano
i used the AI Suite II temporarily to set clock and temp values. once i had the differences,
uninstalled AI Suite and use HWMonitor and know what the offset is.
i used an Inferred Temp Gun for the VRM/MOSFET. shows 84°C A 1.465v 4.8GHZ.
normal 24/7 is 4.5GHz (6% loss in benchmarks - wooo!)
https://linustechtips.com/topic/117753-hows-my-overclock/#findComment-1570969
Much appriciated.
I dropped my NB clock and such back down closer to stock (they bumped up with my CPU), and got better temps (a reduction of like 4 degrees.)
I'm going to aim for 4.5Ghz on my CPU :D That was my ultimate goal for my current cooler (The terrible H70)
https://linustechtips.com/topic/117753-hows-my-overclock/#findComment-1570989
@airdeano
Success!
4.5Ghz stable! (Also, at 69 C. Woot)
1.42V I believe is what it's set at.
Thanks for the help all! :D Super stoked.
Also, Memory clocked at 2099 Mhz :D (1866 Mhz modules)
https://linustechtips.com/topic/117753-hows-my-overclock/#findComment-1571032
Errrrggg... After stress testing for about half an hour, a core failed!
I'm sitting just under 1.44V, my temps are right at 70C...
Is there anything I can do to get this stable?
Or do I need to back off my OC to 4.4?
@airdeano @WoodenMarker
I just tested the 4.5 at the 1.439V, and got a fail after 30 minutes of testing... :(
I guess until I get a better suggestion, I'll back it off to 4.4... So close to my goal...
Maybe I'll try 4.45... :P
I can only complain so much, I'm right around 1Ghz over what stock is...
Here's some pictures of my UEFI screen,
Everything look normal?
(I just feel like the Voltage is a higher than I expected for this level of OC.)
OverClocking_3
OverClocking_1
Edit:
Got to 4475 Mhz, just under my goal... But close as I can get... Prime95 has been running for 45 minutes without issue... Gonna let it continue for a minimum of an hour.
https://linustechtips.com/topic/117753-hows-my-overclock/#findComment-1571093
What kind of cooler are you using?
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/117753-hows-my-overclock/#findComment-1571414
@Prokart2000
Every forum I could find, said that 70C was the max in SYNTHETIC benchmarks.
That your CPU won't actually hit 100% constantly in any gaming environment.
https://linustechtips.com/topic/117753-hows-my-overclock/#findComment-1572583
@Prokart2000
True, but I wouldn't really push the overclock too far on that cooler, since the 8320 does kick a lot of heat when overclocked. I remember that my Corsair H80 wasn't coping very well with high overclocks unless the fans were at 100% all the time.
https://linustechtips.com/topic/117753-hows-my-overclock/#findComment-1572927
A recurring pattern with FX8320s is they get to a point where they require massive (50mV+) jumps per 100MHz. For me that happens going past 4.3GHz.
https://linustechtips.com/topic/117753-hows-my-overclock/#findComment-1574109
@acidydragon
I'm on my phone so I can't quote but you are exactly right. A game won't take you to the same limits that a synthetic bench does. If your cpu runs stable with prime for an hour and a half, its good enough to game with. A 24/7 oc, not so much. I take my 8350 to 4.7 when gaming and back it down to a regular oc of 4.3.
This is all done through an "in-os" overclock so you can change it on the fly. If you can get your bios gaming oc settings into an os oc utility, it will be easier for you to switch back and forth depending on what you are doing.
https://linustechtips.com/topic/117753-hows-my-overclock/#findComment-1574334
My fans stay at 100% all the time anyway. Noise isn't an issue. :P
https://linustechtips.com/topic/117753-hows-my-overclock/#findComment-1574462
