So I have no personal experience with this question, I'm just genuinely curious if anyone knows, Why does ESD cause damage?
I have been searching up online some possible answers and sadly none seem to explain WHY, only that it does it. I don't just mean
"Because its electricity, stupid!" I mean what happens in the components that cause them to die or damage.
https://linustechtips.com/topic/1176656-why-does-static-electricity-cause-damage/
When you get popped by it you are taking a hit with some serious voltage behind it BUT the actual amount of electricity is so small it doesn't really do any harm to you.
For electronics it's different, regardless of the actual amount of electricity it's being induced at such a high voltage it, as said above makes things break.
"If you ever need anything please don't hesitate to ask someone else first"..... Nirvana
"Whadda ya mean I ain't kind? Just not your kind"..... Megadeth
Speaking of things being "All Inclusive", Hell itself is too.
think tiny lightning bolt shooting out of your finger into whatever electronics you're holding.   thats whats happening.
when i was building servers i saw a few instances of ESD burning out parts of the motherboard, but physical damage is rare.   usually it causes issues that are hard to diagnose, ram or processor not clocking correctly, maybe a usb port not working, graphics card not getting enough power. just weird shit, often people think the motherboard is doa, when actually they fried it on accident without realizing it.
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
See Thor.  See Thor point finger.  See Thor finger shoot lighting.  See Thor finger shoot lighting and see electronic explode.  See Hulk Smash.  See Thor immune to lighting.  See human be like Thor and blow up 9900k for the Ryzen God.  See Raiden make you his disciple.
After that, did you look into electricity and how it works?  Fascinating stuff, worth your time.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
ESD has a large effect on integrated electronics (microchips etc, not so much on larger components) for a number of reasons.
There are 2 reasons that I'm aware of;
1. As a static buildup provides a very high voltage, it results in a very large current through the component (U = IR so if U is large, and R is constant, I becomes larger too) and because the microscopic traces and components on say a chip are (by orders of magnitude) not designed for such currents they get destroyed.
2. Circuits may short out because the (also very small scale) insulators break down because of the high voltage possibly applied across them. In the worst case the short is permanent, but even if it isn't, the circuit has likely been destroyed while the short took place.
To clarify here: U in Europe is indeed to signify a voltage, but is not the "unit" voltage, which is still abbreviated V. In some examples you might see E instead of U.
Examples:
U = 2 V
or
E = 2 V
Other than that, I have not much else to contribute here. Most semiconductors' internal structures break down at high voltages, by causing physical damages (like holes). MOSFETs are notoriously sensitive, and are basically the basis of almost all IC's these days.
4 hours ago, Lord Vile said:
I get E I know why that used but U is just dumb. A MOSFET is just a fancy transistor (I know it’s what the T stands for) and if you put too much Voltage in it’ll just blow the thing.
Ir's true that the T stands for Transistor, but MOSFET's and Transistors are completely different. They're both used differently, and have completely different characteristics.
Normal transistors operate on base currents. They amplify the base current by allowing current to pass through collector and emitter. Because they operate on input current, they're less efficient but more robust. Voltages/spikes have much less of an impact, because they conduct the energy and thereby clamp the voltage  They're also basically linear/analog components.
MOSFETs on the other hand operate on gate voltage, not current. They completely rely on the voltage applied to the gate, not the current. so they're much more sensitive, but way more efficient because they have a much smaller linear region, therefore almost always being completely on or off, not somewhere in between.
Well if by "transistor" you mean BJT then yes indeed. Generally though, a MOSFET is considered a type transistor.
U for voltage seems to come from the German word "Unterschied*" which means "difference" which is actually kind of descriptive. Here's my view on it:
  -V for voltage doesn't seem right as the unit Volt is also written as V meaning you can get things like V = 5V.
  -E stands for energy which is such an incredibly common symbol that I refuse to use it for voltage.
U is the best we have because it's a different letter than the unit uses, and even though internal energy uses the symbol U, that isn't as frequently encountered as energy, in EE. It's far from perfect, but it doesn't have the issues V and E have.
I agree the downside is the use of a German word, so perhaps we can use O instead :)
*Proper translation provided by @Curious Pineapple
Older TTL electronics are pretty robust and generally take static discharge just fine. MOS technology however doesnt due to the construction. MOS devices use a piece of either P or N type silicon (or sometimes both in the case of a J-FET) which is non conductive, and a gate. The silicon and the gate are seperate by a layer of aluminium oxide (the MO(Metal Oxide) part of MOS). A high enough voltage blows through that insulating layer and shorts the gate to the silicon which prevents the build up of an electric field, killing the device.
31 minutes ago, akio123008 said:
U for voltage seems to come from the German word "Unterscheit" which means "difference" which is actually kind of descriptive. Here's my view on it:
The German word you are looking for is "Unterschied".
There are many ways to define a nomenclature, it just needs to be properly defined and used consistently. I have always been taught to use U for voltage, E is the electric field strength. If you run out of letters, you can always use different font styles when writing in LaTeX for example.
As for V = 5V, if you set that properly in LaTeX, those Vs will look differently because the second one with corresponds to the unit will be upright, so you have to use \mathrm{V} in math mode or use a package like siunitx that does it automatically.
Thanks.
That's assuming everything you do is in LaTeX or a text editor to begin with.
26 minutes ago, Lord Vile said:
That’s just dumb. You generally don’t put units into an equation unless you’re trying to find the unit because it’s just makes things longer. You use for example V=0.2x10 so V = 2
I agree that it usually doesn't matter, and V is fine, it's just that I don't like using the same letter for both. Also it just depends on what you're used to, I tend to write U without even thinking about it and so do many other people.
56 minutes ago, Lord Vile said:
That’s just dumb. You generally don’t put units into an equation unless you’re trying to find the unit because it’s just makes things longer. You use for example V=0.2x10 so V = 2. If you wanted to be pedantic it would be V = 2 AΩ for this equation.
Either I'm missing something or this is just not true? I've been learned that you always need to add a unit to your answer, so U = 0.2*10 = 2 V. How else would you denote kV and mV?
PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular  - Case: Corsair Obsidian 450D  - OS: Windows 7
Well you're quite right in the sense that at any exam or test you usually lose points for not writing down units (especially in final answers). In most situations though, you could write down "V is the voltage in kV" or "V is the voltage in mV" once, let's say at the top of a page and then in all calculations from there skip the unit.
20 hours ago, Lord Vile said:
Not really a transistor is still a semi conductor requires an activation voltage and breaks down if you give it too much. A mosfet is just a type of transistor that uses the PNP/NPN layer differently.
A "normal" transistor operates on base current, although I'll agree that the base-emitter voltage needs to be at least ~0.7 V before they start working. Of course, if you give them too many volts, they'll break down just as easily. But because there's conductivity from the base to the emitter path, this voltage is reached less easily.
Yep, I did.
18 hours ago, Lord Vile said:
You cut the units out for the equation so it’s V = 0.2*10 = 2 Volts. You add the units in after. You don’t write V = 0.2A*10Ω because that gets to being an arse when you’re writing even PV=nRT with a couple of values swapped out.
With unitless amplifications and gains and a singular unit like Voltage, then usually I would agree with this statement. If you're working with multiple units, like actual resistances and currents, it's really good form to write them out explicitly. No unit implies a gain or factor.
1 hour ago, Lord Vile said:
I get his point saying V = 2V looks a bit wrong at the end of an equation of you think about it that way but in general that’s not the way you’re looking at it.
Generally with multiple resistances and currents I break it down as far as I can before launching them into an equation or if I can get away with it just put them all
into standard form and be happy with that. To be fair it’s electronics not Quantum theory or even thermodynamics gets messy when you’re at degree level.
Ah, I see. In that sense I usually do the same, first write down all the parameters and their units, but in the equations I leave the units out. The values are enough to look back and recognize what the units are.
U is the shorthand for the quantity "voltage", which has the unit V (volt), just like R is the shorthand for the quantity "resistance", which has the unit Ω (ohm). It's practical to have different symbols for the quantity and the unit.
MB: Gigabyte X570 Aorus Master | CPU: AMD Ryzen R9 3900X | CPU cooler: Corsair iCue H150i RGB PRO XT | RAM: Corsair Vengeance 64 GB (4x16) DDR4-3600 CL18 LPX | GPU: Zotac RTX 3080 Trinity OC + Palit RTX 2080 Ti GamingPro OC | SSD: 2 x Samsung 970 EVO Plus 1 TB NVMe + Kingston A400 480 GB + Samsung QVO860 1 TB | PSU: EVGA SuperNOVA G2 1000 W Gold | Case: be quiet! Silent Base 801 | Displays: BenQ PD3200U @ 3840x2160 + ASUS ROG Strix XG32VQ @ 2560x1440 | Keyboard: Corsair K68 RGB Cherry MX Red | Mouse: Logitech MX Master 2S
I've never heard of U being used as the symbol for voltage.  And now it is explained it makes perfect sense.  I am surprised this isn't used more universally. I have attained several qualifications in EE (1992) in Australia and this was never taught.
I guess as it's really the only unit that gets it's parameter name from its unit of measure then it really is the only confusing one.
EDIT: the reason I was never taught it is because V is the SI symbol, and in Australia we only teach strictly to standards (even when convention is more logical).
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
