What am I suppose to look at?
I see a screenshot of 143 and 183fps at a certain moment in time. Is this relevant? Is this bad?
You probably need to clean your PC and apply new thermal paste if it runs at 80 C at 35%
https://linustechtips.com/topic/1172474-can-anyone-help/#findComment-13438125
I wanted to show cpu usage and temps.
I just cleaned my pc about a week ago and I thought since I have stock intel's cpu cooler, better cpu cooler will help
https://linustechtips.com/topic/1172474-can-anyone-help/#findComment-13438132
2 minutes ago, 5x5 said:
All i see is you running above 140fps with ease. Clean the case and fans. Get some new paste. If you want more performance, get a new CPU and GPU combo
I just cleaned my pc about a week ago, I dont have the budget to upgrade my cpu at the moment so was thinking of getting another 8gb ram, a SSD and new cpu cooler temporarily till I have budget for new cpu n gpu
https://linustechtips.com/topic/1172474-can-anyone-help/#findComment-13438140
CPU & GPU usage in the other games might have been more relevant, as I fail to see how getting 140-180fps in a game constitutes as 'issues'.
https://linustechtips.com/topic/1172474-can-anyone-help/#findComment-13438149
my bad on that, I basically just wanted to show usage and temps here so I thought this pic will help
https://linustechtips.com/topic/1172474-can-anyone-help/#findComment-13438155
Considering it's at 83 at 50% useage a new cooler will help. The stock cooler was barely able to cool (and often just wasn't enough) the 3770 so getting a new cooler will help.
https://linustechtips.com/topic/1172474-can-anyone-help/#findComment-13438158
Its probably the paste, if you do want to shell out a few extra bucks on a cooler while youre at it, going to something like a cooler master hyper 212 from an intel stock, will be a pretty good difference. wouldnt spend much more money than what that costs. make sure it fits as well, im not sure if it does, just something along those lines
https://linustechtips.com/topic/1172474-can-anyone-help/#findComment-13438165
yeah, ill definitely try that, thanks for help
https://linustechtips.com/topic/1172474-can-anyone-help/#findComment-13438168
oh and an extra stick of ram, if you only have the 1 already, id add that too. but i dont reccomend intel stock coolers, so you should probably upgrade that too, but thatd be the 3rd thing, 1 paste 2 ram 3 cooler. especially if that cooler was working fine for you first, otherwise, maybe ram 3rd
https://linustechtips.com/topic/1172474-can-anyone-help/#findComment-13438169
once this lockdown is over' ill get a new cooler and see . Thanks for the reply though
https://linustechtips.com/topic/1172474-can-anyone-help/#findComment-13438171
@El Diablo Before getting a new stick of ram most motherboards say that2038895126_Screenshot2020-04-03at6_07.13AM(1).thumb.png.1d8fceeb644c36a905e97ec50f23b232.pngand also it is recommended they be from the same kit.
Quote me for a reply, React if I was helpful, informative, or funny
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1172474-can-anyone-help/#findComment-13438187
