PS5 Monitor?!
KHSZ
Hello bros, I've been looking for a new monitor to be capable of PS5/Xbox Series X.
I've settled between two monitors and would love to hear from you which one should I pick and why?
Firsthttps://www.amazon.com/gp/product/B0829S7178/ref=ox_sc_saved_title_4?smid=ATVPDKIKX0DER&psc=1&tag=linus21-20
Second https://www.amazon.com/AOC-AG241QX-Adaptive-Sync-DisplayPort-QuickSwitch/dp/B01NCTHS6E/ref=sr_1_1?keywords=AG241QX&qid=1584386402&s=electronics&sr=1-1&tag=linus21-20
10 minutes ago, Trinopoty said:
Looks like broken links.
Yeah, my bad
Just updated the links
Asus Pros:
1) Has FreeSync. Since PS5 will use AMD hardware, it probably will support FreeSync.
AOC Pros:
1) Higher resolution.
Depends on what you want. If you have a PC with nVidia GPU as well that you want to use with the monitor, definitely go for the AOC.
On the other hand, if you have an AMD GPU and don't mind the lower resolution, go for the Asus.
6 minutes ago, Trinopoty said:
Asus Pros:
AOC Pros:
I'll just use it for PS5/Xbox Series X
Probably the AOC.
I can't be sure if PS5 for Xbox will support FreeSync or if you will care about that.
It depends. The IPS panel on the Asus monitor would look better color-wise but the resolution is lower than the AOC monitor, but it has a TN panel which sucks for color reproduction. Personally, I favor resolution over panel type, but that's me.
MAIN PC:
CPU: Intel® Core™ i9-9900K Processor  Motherboard: Gigabyte Z390 Aorus Pro Wifi  CPU Cooler: Scythe Fuma 2  GPU: EVGA RTX 3080 FTW3 Ultra  RAM: Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red  Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
SECONDARY PC:
CPU: Intel® Core™ i3-9100F Processor  Motherboard: ASRock Z390 Phantom Gaming 4-CB  CPU Cooler: Arctic Alpine 12 CO  GPU: EVGA RTX 3060 XC RAM: ADATA XPG 16GB (2x8GB) 2400Mhz CL16
Case: CyberpowerPC Onyxia  PSU: ATNG ATA-B 800w 80 Plus Bronze  Storage: 500GB Samsung 850 EVO + 2TB Seagate FireCuda SSHD 5400RPM    OS: Windows 10 Home
Former parts that I've used: Acer XG270HU, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti
1 hour ago, Trinopoty said:
Probably the AOC.
Both should have some degree of freesync support, but I think any issues will more likely be down to whether or not monitors will support the implementation the consoles will be using. Neither will have displayport, so it'll come down to how buggy or otherwise freesync via HDMI is on the monitors.
If you're going to use the monitor only for consoles, there's no proof that the ps5 will support 1440p.
Thus with your budget I would choose a 1080p 60hz monitor, preferebaly with IPS or VA panel.
Wait till the actually announce the release of PS and Xbox, or even till they are released. By then new monitors will come out, prices will drop etc.
  • 2 months later...
