[Python3] random.choce(list) Does not work in *.py file
Go to solution Solved by Slottr,
5 minutes ago, WillLTT said:
Oh lol I see
your python file is called random. You imported the script you’re writing on. You’re not using the module, you’re using your current py file
rchoice = random.choices(list1)
does not work when its in the PY, it spits:
Traceback (most recent call last):
  File "random.py", line 1, in <module>
    import random
  File "C:\Users\Willi\random.py", line 17, in <module>
AttributeError: module 'random' has no attribute 'choices'
But when running the SAME with copy&paste into the shell:
No issues. Runs perfectly.
WHY?
Did you import random?
Yes. i apprichiated the reply :)
i launched python without any manual imports pasted the code in and it works.
However launching the via the py shows the error above.
Just now, WillLTT said:
Yes.
Can you post your script?
Oh lol I see
Just now, Slottr said:
Oh lol I see
ahahahh
i feel so dumb
2 minutes ago, WillLTT said:
ahahahh
i feel so dumb
It gets the best of us sometimes
